40c sprockets
Swawpy
40c sprockets
Post by Swawpy » Sun May 03, 2009 12:33 pm
Need to repair or replace both sprockets on a 40c, and was wondering; are just the outer "rings" available to weld on, or have to find complete new or used?
Swawpy
Post by Swawpy » Sun May 03, 2009 2:12 pm
Thanks Bill- I will try them on Monday.
Post by Lavoy » Mon May 04, 2009 2:21 pm
I have used and NOS on hand.
Swawpy
Post by Swawpy » Fri Jul 03, 2009 11:46 pm
Thanks Lavoy and all. I am still trying to determine just how bad tracks are. Sprockets are definately shot and one idler has a few chunks out of the ridges. I havent measured any bushings, but they look pretty flat and dont look to bad on the outside at all. I can rock every link by hand and feel at least 1/8" of slop.
Is it possible to weld the idlers up and grind even just where I filled?
And I found that 23.51 is 100% worn for a 420, what is the limit for a 40? I measured 23 1/8. I have 31 pads. And took off TE235Y sprockets. Never thrown a track and has plenty adjustment.
This is mostly a toy that gets maybe 30-40 hours a year and just looking to get by with it.
Thanks to everyone, and Happy 4th!
Swawpy
Post by Swawpy » Fri Jul 03, 2009 11:51 pm
Also- Found a local ad advertising 21 new pins and bushings for a 420, M2259T and M2559T. Wants $150 if anyone is interested.
Post by Lavoy » Sat Jul 04, 2009 9:16 am
I have a customer that could use a set if you want to send me the number.
Swawpy
Post by Swawpy » Sat Jul 04, 2009 1:44 pm
Lavoy- I sent an email with info. Do you happen to know the wear limit rail measurement for a 40c?
Post by Lavoy » Mon Jul 06, 2009 9:24 am
Got the e-mail, thanks. No, I don't have specs on the 40, sorry. Only thing that would likely be the same is pitch, 5.75". Across 4 links, 23" would be new, 23.5" is 100% worn.
