throw out bearing face ?
Randy Richards
Post by Randy Richards » Fri Jul 17, 2009 5:28 pm
Just to be sure before I go any further, which way does the throw out set in the assembly? just checking.... thanks Randy
CELSESSER
Post by CELSESSER » Fri Jul 17, 2009 9:48 pm
Randy,
If it is a main clutch throwout bearing you press the bearing onto the carrier with the polished surface out and index the scribe mark on the bearing with the notch in the carrier.
The steering clutch throwout bearings are obvious as to which way they go on thier carriers.
Chuck
Randy Richards
Post by Randy Richards » Sat Jul 18, 2009 6:52 am
I have a 1010 and I'm working on the left steering clutch, which way for the t/o bearing to face?
Post by Lavoy » Sun Jul 19, 2009 11:37 pm
The flat machned surface of the throwout bearing presses against the pressure plate fingers.
Randy Richards
Post by Randy Richards » Mon Jul 20, 2009 6:36 pm
thanks for the simple answer
