420 quill
Eric.MacLeod
420 quill
Post by Eric.MacLeod » Sat Aug 08, 2009 8:19 pm
hello, i just put grease in the ball bearings, all new springs and throw out bearings and tubes in my 420. i was going to button it all back up when i read on here about seals being behind the quill, what holds the quill in after unbolting it? and what keeps gear oil from the rearend from leaking by the quill? does the quills have big o rings around them? thanks ,,Eric
Lu47Dan
Post by Lu47Dan » Sun Aug 09, 2009 11:10 am
Eric , there is a gasket under the quill .
JD Part # M 811T , price from JD $7.49 each
The seals part # is AM1717T , price from JD $19.99 each
Dan
1956 420C with GSC blade
Eric.MacLeod
gaskets
Post by Eric.MacLeod » Mon Aug 10, 2009 5:22 pm
thank you lu47dan.. i will get those parts orded i really dont want to pull it apart again if i can help it, i even went for the metal clutches just in case.. what ever happened to your project? i seen it on you tube as part one but havent seen part two..my dozer has taken a backseat to thomas the trian and the beach!! he starts school this fall so that will free up some time for me :lol:
Post by Lavoy » Mon Aug 10, 2009 6:06 pm
I have the original style AM1717T seals for $10 each if you want. The ones Deere sends now are not shielded, you need to be more careful when putting the quill back on not to roll the seal if you use them.
Eric.MacLeod
seals
Post by Eric.MacLeod » Mon Aug 10, 2009 7:26 pm
thank you lavoy, i will call wednesday and order the seals and gaskets if you have those to. hopfully you can throw some ambition in the box also,, thanks. Eric
Post by Lavoy » Tue Aug 11, 2009 9:09 am
Eric,
I have so little most of the time, I have to keep all I have! :lol:
Lu47Dan
Post by Lu47Dan » Tue Aug 11, 2009 11:20 am
Eric , I have been working on several other projects , I bought a lathe so I could repair the drive axles seal surface and that has been a slow job . I am ordering parts slowly for it . Once the other projects are done then I can get restarted on the crawler again .
I have also made several drivers for various seals and bushings . Having the lathe has been great , it has almost paid for itself by saving me money and making money from projects that other people needed done . 8)
Dan
Eric.MacLeod
Post by Eric.MacLeod » Tue Aug 11, 2009 5:39 pm
hello dan, i wish that i had a lathe also. i can understand working on other peoples projects, in this day and age any job that pays is great news, keep us posted on the progress, im slowly working on mine, someday ill finish it.. see ya. Eric
