lp14255
Post
by lp14255 » Tue Nov 24, 2009 5:37 pm
hello everyone im new to this site and need a little help. i just bought a 350b dozer and need some info on it. the plate on the dozer says the type is t4f3d and the serial is 092807t . what year is it? and it makes a rattling noise when i turn off the motor, it sounds like it coming from the trany. the gentleman i purchased it from said it was the clutch inside the bell housing in between the trany and motor . it this normal?
- Site Admin
Post
by Lavoy » Tue Nov 24, 2009 5:41 pm
That is a straight 350, 1968, not a B model. Your reverser lever should be on the dash.
The rattle noise is the drive for the reverser, mine makes the same noise. I put all new springs in, quited it down some, but still there.
lp14255
Post
by lp14255 » Tue Nov 24, 2009 7:08 pm
Lavoy wrote:That is a straight 350, 1968, not a B model. Your reverser lever should be on the dash.
do you know where i can get the vavle spool o-rings for the control vavle used to move the blade around.
- Site Admin
Post
by Lavoy » Tue Nov 24, 2009 8:17 pm
A good hyd shop may have them, or from Deere.
KenP
Post
by KenP » Wed Nov 25, 2009 5:22 am
deleted
KenP on Sat May 25, 2013 5:31 pm, edited 1 time in total.
lp14255
Post
by lp14255 » Fri Nov 27, 2009 8:05 pm
KenP wrote:The isolator on my 350 rattles as well when its shut down. Its worse if I don't reduce the RPM to idle before shutting it off, so I always try to minimize the spring movement by idling first.
Don't know for sure, but I suspect its a lot easier on the springs and mounts that way.
can you but a turbo on it increase the power?
KenP
Post
by KenP » Sat Nov 28, 2009 6:01 am
deleted
KenP on Sat May 25, 2013 5:32 pm, edited 1 time in total.
- Site Admin
Post
by Lavoy » Sat Nov 28, 2009 9:32 am
I'm sure you can, just remember to save up extra money after putting the turbo on to buy drivetrain components. Like Ken said, if you need that much power, get a 400G or a 450.
Users browsing this forum: No registered users and 139 guests
