air intake vent
lp14255
air intake vent
Post by lp14255 » Sun Sep 25, 2011 2:03 pm
i hace a 350 crawler and on the back of the air filter housing theirs a barb fitting , and under the instrument panel is a sort peice of dry rotted tubing i guess goes to the barb fitting. does the end of the tubbing stay open or does some sort of breather cap go on it ,
1969 jd350 crawler dozer
CatD8RII
Post by CatD8RII » Sun Sep 25, 2011 3:24 pm
I'm pretty sure it should go to your air filter restriction gauge/indicator.
lp14255
Post by lp14255 » Mon Sep 26, 2011 5:47 pm
ok thanks , where does the indicator go on the machine ?
dozerman58
Post by dozerman58 » Mon Sep 26, 2011 8:10 pm
some are mounted clost to top of engine around dip stick in plain view. Look for a bracket bolted down with a hole in it. That be where that gizmo bolts on i think.
KenP
Post by KenP » Tue Sep 27, 2011 3:02 am
deleted
CatD8RII
Post by CatD8RII » Tue Sep 27, 2011 9:44 am
On my 350C loader, its mounted right above the air cleaner, which sits between your legs sitting in the seat. I would consult your operators manual, it should cover checking the indicator and air cleaner.
lp14255
Post by lp14255 » Tue Sep 27, 2011 2:18 pm
thanks guys for help.
Users browsing this forum: Google [Bot] and 233 guests
