Brake band
gregjo1948
Brake band
Post by gregjo1948 » Sun Oct 07, 2012 7:40 am
Will brake bands from a 350 JD interchange with bands on a 1010 JD ? Thanks, Greg
Post by Lavoy » Sun Oct 07, 2012 10:35 am
I should, but not a blanket statement depending on 350 series, and if the 1010 has never had the conversion to the later brake parts.
gregjo1948
Brake band
Post by gregjo1948 » Mon Oct 08, 2012 7:43 am
Thanks Lavoy. I haven't been in to it yet. The clutches release OK and don't slip. I have them adjusted per JD shop manual. The brakes hold good if applied before the machine moves in either direction. They work fine if applied using the shuttle. (In the slight hesitation between direction) If applied during machine motion, it doesn't want to stop a track. I'm sure they're adjusted correctly; I'm thinking the bands are shot. Any ideas? Thanks, Greg
Post by Lavoy » Mon Oct 08, 2012 7:48 am
Might be oil contamination?
gregjo1948
Brake band
Post by gregjo1948 » Mon Oct 08, 2012 8:21 am
If it is oil on the band, wouldn't the clutches slip? Greg
Post by Lavoy » Mon Oct 08, 2012 4:04 pm
Depends on how far it has migrated to, but if not, it will get there eventually.
gregjo1948
Brake band
Post by gregjo1948 » Mon Oct 08, 2012 4:18 pm
Thanks again Lavoy-- When I open it up, do you have the seals, bearings, bands, and etc. that I will need to repair it correctly? Thank you,Greg
Post by Lavoy » Mon Oct 08, 2012 5:31 pm
Normally I do, sometimes I may be temporarily out of stock.
