1010 diesel crank case oil capacity
ktheaker
Post by ktheaker » Thu Nov 22, 2012 2:02 pm
i purchased a basket case 1010 diesel and it does not have a dip stick and im going to dump the oil and try and cranck it over and see if i can get it to light up . what is the capacity of the crank case and is the stick the same as gas or diff, i do have a gasser already and it would make the check easy .thanks
kt
Post by jtrichard » Thu Nov 22, 2012 3:02 pm
yes gas and diesel are the same unless one is very early and the other is the later model.... does yours have a 1 1/2" tube for the stick? if so there is one for 2010 on ebay for $15.... 2010 /1010 same dip stick
ktheaker
oil capacity
Post by ktheaker » Thu Nov 22, 2012 3:04 pm
i believe it may be , i will check thanks
kt
Post by jtrichard » Fri Nov 23, 2012 12:38 pm
engine oil capacity should be 6 quarts with filter
ktheaker
Post by ktheaker » Wed Nov 28, 2012 7:08 pm
thanks very much , for the reply
kt
Users browsing this forum: No registered users and 31 guests
