New 420c project
Bnichols
New 420c project
Post by Bnichols » Thu Dec 06, 2012 3:56 pm
I'm new to this. I have a 420c that I don't know anything about. I'm 23 and never messed with any of these. It was my grandpas and it been apart longer than I can remember and I'm 23.He pulled the engine out 15 or 20 years to rebuild the engine and it never got back together. I'm trying to put it back together from pics I've seen. I just got the engine built and installed with a new clutch. I'm pulling on firing it up this weekend and see what happens.
Bo Nichols
Post by jtrichard » Thu Dec 06, 2012 4:09 pm
left track is on backwards
Post by Lavoy » Thu Dec 06, 2012 5:38 pm
What you have is a 5 roller 420 with #62 blade. Serial number will be on the LH side of the center section, kind of by the sediment bowl.
05victorylly
Post by 05victorylly » Thu Dec 06, 2012 5:54 pm
I hope you get her running!! Sounds like a good project and should be a great little machine once you get her all buttoned up and working.
IH 500 6-day dozer , JD 2010 track loader, Ford 1900 4x4
Bnichols
420 Project
Post by Bnichols » Thu Dec 06, 2012 6:08 pm
Thanks for telling me about the track I haven't caught that. Thanks for the info Mr. Lavory and thanks to everyone else also. So it has four foward gears. Did they do alot of 4 speed with a reverser?
Bo Nichols
Bnichols
420
Post by Bnichols » Thu Dec 06, 2012 6:16 pm
The serial # is 130437 What does this tell me?
Bo Nichols
Post by Tigerhaze » Thu Dec 06, 2012 6:44 pm
It tells you that your 420 is a 1958 model:
http://www.jdcrawlers.com/messageboard/ ... c.php?t=35
It is also helpful to know because sometimes parts are different within the same model for different serial number ranges or are interchangeable between different models. Lavoy or others can better tell you that for a 420, or you can do some searches of the archived posts on here for some of that information.
Post by NNAATZ » Thu Dec 06, 2012 8:07 pm
looks like you have a good crawler to start with.
Users browsing this forum: No registered users and 41 guests
