Water
mapaduke@yahoo.com
Water
Post by mapaduke@yahoo.com » Sat Dec 22, 2012 6:00 pm
Just wanted to say how important it is to keep your tractors covered up when not in use. I just rebuilt a trans for an MC that that otherwise would have just needed an oil change if it wasn't for the pitting and corrosion from water in it. 6 new baring's and one for the belt pulley, 2 speedy sleeves 5 seals and a used input shaft with cluster gear = $921.50 A good tarp priceless
nothing crawles like a deere
DukeofDeere
Post by DukeofDeere » Mon Dec 31, 2012 1:39 pm
Even with a good tarp or in the shed here in the north country these crankcases and gearcases get condensation which I drain off each spring. Most have about a cup of water in them.
More if left out in the rain.
Drained a Jd D last week. Had over 5 gallons of water in it. :shock:
A good silicone calk to seal crankcases covers priceless.
Best to keep em dry.
Duke
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Dec 31, 2012 3:29 pm
It doesn't help that the drain plug is under the foot rest. I think a lot of people neglect to change the oil because its hard to get to.
You are right about the condensation witch reminds me that I should check my other crawlers this spring.
