1963 JD 1010 crawler fan belt replacement
304thomas55
Post by 304thomas55 » Sat May 04, 2013 8:24 pm
Do to a leaking valve cover gasket I must change the fan belt. It appears that it runs off the crankshaft pulley which drives hydraulic pump. Can anyone tell me how to change the belt.....simple or not ?
shinnery
Post by shinnery » Sat May 04, 2013 9:38 pm
Get one of the adjustable length bolt together belts and cut the old one off and thread the new one around where it needs to go. Bolt it together at the right length and adjust the tensioning device.
304thomas55
Post by 304thomas55 » Sat May 04, 2013 9:41 pm
who carries this type of belt?
vtjoe
your belt
Post by vtjoe » Sun May 05, 2013 7:47 am
McMaster Carr red segmented different widths available and actually not bolted but with a sort of removable rivet system
1957 420C four roll since 1982
304thomas55
Post by 304thomas55 » Sun May 05, 2013 5:10 pm
ok thanks for the info :)
304thomas55
Post by 304thomas55 » Wed May 15, 2013 7:12 pm
well folks after some medical issues and some inclement weather, repaired oil leak and found the link type fan belt of all places , Harbor Freight for $22... if there' s a need try Harbor
