455G no fuel during hot restart
The machine didnt start back up after I filled it with fuel. I did notice some serious vacuum when I unthreaded the cap but I figure I had just been running it for 6 hours or so, and it probly just used more fuel than the breather would allow air to replenish. I was told to look at shutoff selanoid (sp?) that is apparently inside the fuel pump. I was also told to check for a primer valve and filter between pump and tank (located neither even with the panels all off). Anyhow I only got as far as checking the 12volts to the shutoff selanoid and it is present when the key is on.
455G with 9310G hoe
check the tank vent make sure it is clear...then see if you have fuel to the filters (change the filters?and blead)...then see if you have fuel to the pump...... crack the injector lines.. crank till you get fuel tighten and then see if it starts
I only pulled the left shields as the tank and pump are both on left side of machine. Is there a manual primer on it also? I am thinking tank vent is clogged with stink bugs or dirt and it lost prime. Ive only put about 200hrs on this machine so far so aside from the undercarriage I havnt delved into any other service besides grease. lol
455G with 9310G hoe
