76 jd dozer, having left brake problems....
800screws
Post by 800screws » Mon Jul 08, 2013 8:38 am
I have a 76 jd dozer...the left pedal has increasingly fell farther and farther to the floor with now almost no brake....I tried the adjusting bolt, which made the pedal stiffer, but I lost all braking power after doing that....I really don't know how the braking system even works on the dozer. I followed the linkage to what im guessing is a bypass valve for the track hyd.
does the dozer have pads? and a caliper? if anyone has pics on how to put new brakes on, and instructions, id greatly appreciate it....really need to get the dozer going again.
the right side is fine also..........
Post by Lavoy » Mon Jul 08, 2013 10:21 am
Not quite enough info, but I will assume you have a 350 with a reverser. The LH pedal is the clutch pedal, nothing to do with braking or steering. All steering brake control in done with the steering levers.
800screws
Post by 800screws » Mon Jul 08, 2013 11:59 am
sorry...its a 550-c....has the 3 pedals for brakes...left, both, right...its always moving when in forward and reverse, has the deceleration pedal...and u stop or steer with the pedals....
it moves, just the left track will not stop to steer.
800screws
Post by 800screws » Mon Jul 08, 2013 12:07 pm
its kind of like this setup...but this is from a 89...
http://www.justanswer.com/heavy-equipme ... lways.html
im not sure what I should be checking...
I tired adjusting "I" on the diagram...but it did not help.
Post by Lavoy » Mon Jul 08, 2013 2:46 pm
Okay, way past me, I will move the thread to the late model forum, you will get more answers there.
Users browsing this forum: No registered users and 9 guests
