2010 Water Pump Kit
Dozerparts
- Contact:
2010 Water Pump Kit
Hi All,
I'm looking to buy a Water Pump kit for a 2010 crawler.Engine # T17513T.
Anyone know where I can get one?
thanks,
thanks,
there is no kit that i know of .... the bearing and seal can be had from other sources the impeller is JD ONLY and is at least $100 last i knew....and the seal surface on the impeller wears and wont seal so good luck impeller part# T574T seal# R32622R retainer #R1529R bearing #JD8582
I can get kits, but they don't include the impellor. Right or wrong, I have faced some impellors in the lathe and reused them.
I guess if it doesn't leak or blow apart then it is rightLavoy wrote: Right or wrong, I have faced some impellors in the lathe and reused them.
Don't know if I would go that far, but it has worked in the past.
Assuming the impeller is brass or bronze, could you build them up with acetlyne torch and brass then turn then down smooth?
- DukeofDeere
I would assume brass would be too soft and the seal would eat it in not time.
- DukeofDeere
Users browsing this forum: No registered users and 88 guests
