1010 crawler injector pump install
JSIMONSON2006
Post by JSIMONSON2006 » Mon Sep 30, 2013 7:05 am
i installed my injector pump in my 1964 1010 crawler i installed the pump lined the marks up and bleeded the lines... well it puffed white smoke then ran good for 15 minutes and smoke disappered and ran good... then i moved the machine and when to idle down and the machine choked out and wont start back up ..did i blow the pump up ? :( i looked at the injector pump and it seems that the one line coming out of the pump is not letting fuel out what can be the problem...it is the line the is near the front of the engine closest to the engine on the left ...
Post by jtrichard » Mon Sep 30, 2013 11:34 am
pull the timing cover on the pump and see if it is turning when you crank the engine over
JSIMONSON2006
Post by JSIMONSON2006 » Mon Sep 30, 2013 12:15 pm
if it is not spinning .. does that mean i broke the pump?
Post by jtrichard » Mon Sep 30, 2013 1:08 pm
YES... the head could have seized and or the shaft broke... i put a pump on my 2010 once and did not see i had dropped a banjo washer and fired it up ran great but one line was leaking i grabbed a wrench and tightened it up and BANG seized the head and she stop instantly :( :(
JSIMONSON2006
Post by JSIMONSON2006 » Mon Sep 30, 2013 1:32 pm
ouch .. so did u have to take the whole engine apart ....the engine on the crawler is trying to turn over ... so i have that going for me .. i just found in the manual that there is a shutoff line that is connected to the pump i didn't hook it up because it was not attached before ... i think it moved and closed that is possibly why i am not getting fuel ... i hope
Post by jtrichard » Mon Sep 30, 2013 8:08 pm
only had to pull the pump and take it back to the re-builder that i just paid about $800 to and hand him another $400 just another day in Paradise :o :cry:
JSIMONSON2006
Post by JSIMONSON2006 » Wed Oct 02, 2013 5:25 pm
Well the tractor started and it was blowing smoke for a bit ..running for 15 minutes it sounds like the timing is off or something it was not running it full power ..all the lines were bleed ..I can't figure out what the problem is after I was done working on it I shut it down try to started back up and it would not start up ..any help out there on this issue
1964 1010 crawler diesel
