1010CID miss fire
gregjo1948
1010CID miss fire
Post by gregjo1948 » Tue Oct 01, 2013 8:20 am
My 1010 misses on one cylinder when not under a load. When throttling up, it runs up smooth, but after rpms plateau, it randomly drops one cylinder. When it drops the cylinder, it gives a slight puff of blue smoke. Could it be an injector malfunction? Also it has no tachometer , but I don't dare run it wide open because it sounds like it will really over wind. The governor seems to be working as it should, when starting to labor it will open the throttle. I don't need to run it full throttle anyways, because it has enough power in second gear to spin both the tracks. I am just curious about the over rev. Thank you guys, gregjo1948
original possum
Post by original possum » Tue Oct 01, 2013 6:17 pm
Sounds like a vacuum leak on that cylinder, assuming it is a gasoline engine. There is less vacuum when the throttle opens.
Post by jtrichard » Tue Oct 01, 2013 9:27 pm
im guessing that since you put 1010c"ID" its diesel .......blue is generally engine oil ..you sure its not white? that would be unburnt fuel ...when it starts up does one cly. take awhile to fire?
shinnery
Post by shinnery » Tue Oct 01, 2013 10:52 pm
His question "injector malfunction?" also sorta indicates diesel. Pretty sure there were no fuel injected gas 1010Cs. Just a theory of course.
gregjo1948
Post by gregjo1948 » Wed Oct 02, 2013 4:22 am
This is a diesel. I put CID by mistake. Should be ICD I believe.The small puff of smoke appears to be blue, as if, it is oil burn. It's very slight so , it may be white mixed with the normal diesel exhaust. It doesn't limp when the engine is under any work. Basically, when the governor is open. gregjo1948
Post by Lavoy » Wed Oct 02, 2013 7:58 am
I would lean towards a bad injector seeing as how it is only one.
Post by jtrichard » Wed Oct 02, 2013 10:26 am
i would agree with Lavoy on the injector .... as for CID VS ICD it would be 1010C DIESEL ....440 WOULD BE 440ICD
gregjo1948
Post by gregjo1948 » Thu Oct 03, 2013 4:47 am
Thanks on the injector replies. I'll isolate the limping cylinder and swap injectors with a healthy one to confirm the diagnosis. gregjo1948
shinnery
Post by shinnery » Thu Oct 03, 2013 6:27 pm
One of the remote infrared thermometers for checking exhaust manafold temperature is a pretty good troubleshooting aid. Misfiring cylinder is cooler. HTH
gregjo1948
Post by gregjo1948 » Fri Oct 04, 2013 5:02 am
Thanks Bryce but I don't have one. I think I'll be able to locate the limper by cracking open injector lines 1x1 and watching for engine reaction. It has worked before on a Mack truck I had. gregjo1948
Flurrdogg
Post by Flurrdogg » Tue Oct 08, 2013 5:40 am
I would say its a injector malfunction you can re time the injector and go from there, Both exhaust valves and injector should be re timed then replace injector and re time again. If it still puff's blue smoke your rings may be bad...
john deere ICD 440 Crawler... Got problems starting..
