thoughts on this 440?
oscar94
Post by oscar94 » Tue Oct 29, 2013 12:17 pm
whiteclipse16
Post by whiteclipse16 » Tue Oct 29, 2013 12:32 pm
Doesn't look too bad in the pics. The tracks do look to be adjust out pretty far.
Not sure how far you want to drive, but there's a gas one in central Ohio on ebay right now for about $2,999 OBO.
Might be able to get it for $2300.
Ben
oscar94
Post by oscar94 » Tue Oct 29, 2013 1:07 pm
Ohio might be a stretch. Sure don't seem to be many of these down here in NC :(
Not sure how much life those tracks might have in them before they need replacing or rebuilding.
Post by Lavoy » Tue Oct 29, 2013 3:23 pm
Tracks are gone, adjuster is past the end of the track frame, so just assume pins and bushings at the least. Might need rollers as well, I would go and look at it in person if you are close enough to do so.
The definition of completely rebuilt means about 10,000 different things to different people, so I would find out EXACTLY what was done to the engine right down to under size on the crank, head work, injectors, etc.
Post by jtrichard » Tue Oct 29, 2013 4:33 pm
Agree with Lavoy 100% .....the adjusters are way past "maximum adjustment" and you need as much info on "rebuild" as you can get
oscar94
Post by oscar94 » Tue Oct 29, 2013 5:28 pm
Thanks so much guys. I am dying for one of these and unfortunately very ignorant about what I am getting in to. I have been reading as much as possible, but nothing replaces some experienced eyes!
Any thoughts on a fair price for this thing assuming the engine is up to snuff?
DukeofDeere
Post by DukeofDeere » Tue Oct 29, 2013 6:17 pm
If she steers well both ways $5500
$1200 is the value of the 3 point alone!
Duke
shinnery
Post by shinnery » Tue Oct 29, 2013 6:29 pm
Also no reverser linkage so probably no reverser. Three point hitch is extra.
gregjo1948
Post by gregjo1948 » Wed Oct 30, 2013 5:18 am
There's no track adjustment remaining.Undercarriage poor? Missing side cover for hydraulic control valves. (Not a big deal.) Doesn't appear to have a reverser. Manual tilt and angle on the blade. Sounds like a lot of work and money invested, but probably pins/bushings needed and possibly idlers and rollers. 3pt hitch and PTO are pluses. Might be worth the money if all it needs is pins/bushings. gregjo1948
