440ICD oil pressure
440ICD oil pressure
Bad day yesterday and it got worse when i had to start the 440 that hasnt been run for a few months and was supprised to see no oil pressure. Pulled the line off the block and no pressure there too... Before i start ripping and tearing.... anyone have any thoughts. It usually ran 40 PSI cold and 30 warm.. so this wasnt expected. Thanks...
This is your 2-53 diesel I presume? You have checked it is full of oil? The oil filter is just a bypass system on them. You might pull the valve cover and see if the exhaust valves and rockers are getting oiled.
- DukeofDeere
2-53 oil pressure
how long did you run it ?
maybe the gauge is stuck.
any pressure at the fitting?
did it start ok and run ok otherwise?
oil pump key that would sure make sense... thanks... to the other replys.. yes good oil in it 2-53 and no pressure at the block i figured the belly pan and oil pan were coming off for sure.. Was going to check the manual and dive in,, but helpful hints always are appreciated
- DukeofDeere
I saw that in the book... I havent dove into it yet.. ran it long enough to test it .Just was looking at it again and found i was checking the pressure on the return side to the block so will do a little more research but even on the return side i should have had oil coming out the unconnected line.
I think before i dive into the front i will drop the pan first and check the pickup. Thanks its always nice to hear other ideas before you dive in.
- DukeofDeere
Success.. !!!!!! on the pressure side i am getting pressure now !!!! return line was plugged...helps to test the right side to begin with before you get stressed..lol was having a terrible day the day it happened wasnt thinking straight. Thanks again
- DukeofDeere
- Paul Buhler
Glad you found your problem, and that it wasn't too difficult to fix.Success.. !!!!!! on the pressure side I am getting pressure now !!!! return line was plugged...helps to test the right side to begin with before you get stressed..lol was having a terrible day the day it happened wasn't thinking straight. Thanks again
My dad, a pretty good mechanic, used to say that we usually expect/predict the worst when something malfunctions or breaks down. He'd keep that option on the table, but then looked for simpler causes, or root problems and solutions and usually he found one.
That wisdom has saved me a bit of money and extra effort over the years.
J
Users browsing this forum: Canuck 420c and 12 guests
