New member new owner 440ICD
gryyde84
Post by gryyde84 » Thu Nov 14, 2013 2:40 pm
Hello all I just so happen to be the new owner of this dozer. I'm excited and looking forward to getting it running. So many questions will follow.
I removed the blower to check for any blockage. I can't get it to hit at all with or without ether. I'm currently trying to get #1 piston up to check valve adjustment. how do you rotate engine by hand or a tool. My starter sticks and continues to turn engine when starter button is released. I have to remove battery post to stop starter.
Thanks in advance for all help in advance.
Post by Lavoy » Thu Nov 14, 2013 3:55 pm
Starter needs a new solenoid.
Hard to turn by hand unless you have the belly pan off. If you have a PTO shaft in it, I have turned them over with a wrench on the PTO shaft.
gregjo1948
Post by gregjo1948 » Fri Nov 15, 2013 5:51 am
Put in gear and use a come-along to pull it. gregjo1948
gryyde84
Post by gryyde84 » Fri Nov 15, 2013 1:12 pm
Great idea with comealong. What do you guys think would make starter hang?
gryyde84
Post by gryyde84 » Fri Nov 15, 2013 1:16 pm
Sorry didn't see new solenoid mentioned earlier but this is a rebuilt starter and new solenoid.
DukeofDeere
Post by DukeofDeere » Fri Nov 15, 2013 1:30 pm
The starter key or push button may need replacing.
Check the wire to the solenoid with a test light or meter while moving the start switch.
Duke
gryyde84
Post by gryyde84 » Tue Nov 19, 2013 10:13 am
Okay couple more questions. Where do you guys buy your parts? I think that my blower will need to be replaced due to the turbines being scored on the edges. I'm thinking that it's not pushing air to the cylinders which may be why it doesn't hit on starting fluid. Can I sand these smooth?And from what I've read the S45 injectors are not helping.
gregjo1948
Post by gregjo1948 » Wed Nov 20, 2013 6:14 am
The owner of this web site (Lavoy) has parts and advice. gregjo1948
whiteclipse16
Post by whiteclipse16 » Wed Nov 20, 2013 7:47 am
I think those impellers are aluminum, so they'd probably be soft enough to polish some. However the lobes have a very tight tolerance, so you must maintain that. I don't remember if you can adjust the impellers to get the gap you need or if they're fixed.
I think they'd have to be scored really really bad to not be pushing enough air to get it to fire at all.
You need to check and make sure the rings aren't stuck and check your valve adjustment. Sounds to me like you don't have the compression you need.
Ben
gryyde84
Post by gryyde84 » Wed Nov 20, 2013 9:06 am
Thanks again guys thats really what I was hoping to hear. I was hoping that the blower was not shot to the point that it would prevent it from pushing enough air to fire. I can now focus on just preparing to do the rebuild. Looks like it is going to be time for a rebuild due to valves adjustment checking out ok. So who has the rebuild with the N pistons and injectors? And what is the going price these days. I keep seeing that this could be done for cheap on a 2-53.
Post by Lavoy » Wed Nov 20, 2013 9:58 am
I can get kits for you, but check with your local Detroit dealer, you might be surprised how competitive he is.
Users browsing this forum: Canuck 420c and 16 guests
