440 ic direction reverser trouble
Post by Lavoy » Wed Dec 18, 2013 7:34 pm
Not necessarily, depends on serial number.
Regardless, the transmission has a reverse in it, so one of the slots had to make it go backward with the reverser in forward, period, no other possibility. 2nd and reverse are opposite of each other on the shifter.
john b
Post by john b » Thu Dec 19, 2013 6:32 pm
so i went out to the shop just to check myself . with the reverser in the forward position the machine moves forward with the tranny shifter in all 5 slots. my understanding is the gear pattern in the tranny is R-1-2
4-3
IM STUMPED.
'58 d-4, '48 ford f-6 dumper,'59 440i.c.
john b
Post by john b » Thu Dec 19, 2013 6:33 pm
ANYWAY, the machine wont go backwards in any of the 5 positions
Post by Stan Disbrow » Thu Dec 19, 2013 8:40 pm
You have a reverse lockout on the shifter cover? You should have.*six* slots. Five forward. One reverse. Often times, there is a lockout plate for the reverse gear position so the lever cannot go into reverse.
There is a restriction against putting the trans in R and the reverser in R to gain an extra forward speed. So, there is usually that lockout plate with reverser equipped machines.
You *can* use the reverse in the transmission as long as you have the reverser in forward.
gregjo1948
Post by gregjo1948 » Fri Dec 20, 2013 5:37 am
Good call Stan! gregjo1948
wizner85
Post by wizner85 » Fri Dec 20, 2013 7:24 am
Had many issues with a reverser and lockout tab. Seen an actual tab on the shifter, a piece welded on the shifter, and also a bolt In the reverse slot. Reverse is all the was left and usually up. Send a pic of what is going on and we can help.
Bought a 440 this summer at an auction and forward clutches were out and it had a bolt in the reverse tab. I didn't have my tool set with me, so I used a pipe to beat off the bolt and used reverse reverse to go forward and load in my trailer.
Some were in amazement I had it moving forward since it was sold as is with reverser issues. I know you shouldn't use reverse reverse, but I only moved it 100 feet and on a trailer.
Andrew
Post by Lavoy » Fri Dec 20, 2013 8:30 am
Reverse and 2nd are on the LH side of the shifter tower. If you don't have two slots there, then a tab has been welded in the shifter tower. Take the tower off, you should be able to see what has happened from underneath.
Do you have a service manual, there should be multiple pics of it in there.
Post by Stan Disbrow » Fri Dec 20, 2013 11:35 am
Well, using dual reverse to just move the machine is not what I think they had in mind when they made up that particular restriction. And, you were stuck otherwise. And, knew you had to deal with a bad reverser anyway. As always, rules have exceptions!
I hope John B's issue is simply R is locked out, as he can get back to work once he finds R in the tranny and leave that reverser work until later.,
john b
Post by john b » Sat Dec 21, 2013 1:26 pm
thanks for all the input guys. i did pull the cover from the shifter tower and sure enough there is a tab welded in to lock out the bottom left position. however , i still cant seem to get her into that shifter position with the cover removed with the machine running or shut down. its like it isnt there. im still stumped, lucky for me i have a warm shop and its a good excuse to hang out up there & escape my wife's honey- do list down at the house. i wouldnt have bought an old crawler if i didn't like working on them, but i sure would like to be out in the woods getting something done
Post by Lavoy » Sat Dec 21, 2013 1:38 pm
Might be sticky due to lack of use for that many years. If you have to, you can pull the shifter cover off and try it while on the bench.
john b
Post by john b » Sat Dec 21, 2013 4:35 pm
i finally got it. there was also a spacer on the shifter shaft preventing the fork from engaging reverse( like a piece of pipe slipped over the shaft during assembly at the factory)so i took it apart, removed the spacer, put it back together and i now have reverse. ill still have to tear it down and get the reverser rebuilt. i need that low gear reverse around here, much of my logging is in steep country. but, at least i can load trucks on the flat landings. thanks again everyone. im sure ill have more q's soon
