430 crawler winch
hokster
430 crawler winch
Post by hokster » Fri Dec 27, 2013 3:40 pm
i have a gearamatic winch with two control handle mounted on side cover what is the model of this winch and where could i find a cover for it handle side cover
Post by Lavoy » Sat Dec 28, 2013 9:38 am
IF there are two handles mounted to the winch, that sounds like a Carco. 8A Gearmatic has no levers, 8G has one on the RH side.
hokster
430 winch
Post by hokster » Sat Dec 28, 2013 10:21 am
Thank you for the reply lavoy. The winch has gearamatic drum winch stamp in the side of it if I could figure out how to post picture of it I could send it to you. It does have to controls on right side.
Post by Lavoy » Sun Dec 29, 2013 10:02 am
Only Gearmatic I know of with a shifter is the 8G, and there should only be one lever.
If you can send me a pic, I can post it.
gregjo1948
Post by gregjo1948 » Mon Dec 30, 2013 6:19 am
The 8G should have one lever for engage/diengage on the winch and another lever mount on right side of the seat for the brake control. gregjo1948
hokster
430 winch
Post by hokster » Mon Dec 30, 2013 6:48 am
Thank you to Lavoy Paul gergjo 1948 and others I have figured out it is a 8g. This web site is awesome and going to enjoy using it in my two rebuilds. Thanks everyone
gregjo1948
Post by gregjo1948 » Mon Dec 30, 2013 7:00 am
If you rebuild a 430 or 420, you need deep pockets. If you rebuild both, does it mean you need deep pockets x2 ? :) gregjo1948
hokster
Post by hokster » Mon Dec 30, 2013 8:54 am
yes i know but 430 has almost new under carriage and is in real good running order mostly cosmetic work. 420 also has great undercarriage but stuck steering and motor from setting :D
gregjo1948
Post by gregjo1948 » Mon Dec 30, 2013 9:27 am
If you can get the engine freed up, try bumping the dozer into a tree or something that won't move easily. Hold the turning clutch back. I have also had luck freeing by holding the clutch and snapping the main drive clutch. The quick jolt will sometimes break it loose. It seems to work better in a higher gear. gregjo1948
hokster
Post by hokster » Mon Dec 30, 2013 2:13 pm
My problem is the lever seems dead no resistance when you pull back on it only right side works. it steered good when we parked it two years ago. got any suggestions any help is real nice. if we need to tear down so be it, just looking for the easy way out. :D
Post by Lavoy » Mon Dec 30, 2013 2:54 pm
If no resistance, the fiber discs have absorbed moisture and swelled so the pressure plate fingers are smashed down on the pressure plate frame. Only fix is tear down and replace. Be sure to check everything while you are in there, that is the time to fix whatever is bad.
hokster
Post by hokster » Mon Dec 30, 2013 3:21 pm
Thanks Lavoy
