jd 1010
1010c
jd 1010
Post by 1010c » Thu Feb 13, 2014 9:23 pm
Hello everyone I was just wondering when I drive my bull dozer the bottom rollers roll 3 or 4 times than stop than roll again is this normal?
Post by jtrichard » Thu Feb 13, 2014 9:53 pm
if the tractor is moving and there is weight on all the rollers then NO its not normal
Post by Tigerhaze » Fri Feb 14, 2014 1:25 pm
This would be an indication of lack of lubrication in the rollers, causing them to stop rolling. My guess is that the inner roller surfaces are also "flat spotted" which exacerbates the issue.
There is another recent discussion thread you can find about checking rollers in case you don't know the procedure to do so.
1010c
1010
Post by 1010c » Fri Feb 14, 2014 2:43 pm
Thank you guys I will put more oil in the rollers also you dont think that this is occuring because of track tension? The tracks are with in the old jd specks .
gus
Post by gus » Fri Feb 14, 2014 4:01 pm
Frozen grease/oil in the rollers???
gregjo1948
Post by gregjo1948 » Sat Feb 15, 2014 6:57 am
TIGERHAZE--exacerbates is a pretty big word for me! Sounds like something I did in private as a teenager. :shock: gregjo1948
Post by Tigerhaze » Mon Feb 17, 2014 10:22 am
LOL, yeah now looking back at the post it is pretty funny. When I post from work (I'm an engineer) I tend to use words I wouldn't normally use elsewhere.
