Transmision Gasket
Bro.Greg
Transmision Gasket
Post by Bro.Greg » Wed Mar 19, 2014 10:29 am
I'm looking for a gasket for my john deere 450 crawler. JD said it is not available through JD anymore. DO you have an idea of where I can get one? The number is T20774. Tractor sn #T5E3M101119T I'm trying to rebuild my trans. thank you for your time.
Greg
shinnery
Post by shinnery » Wed Mar 19, 2014 7:14 pm
Buy gasket material at a parts or bearing house, it is available in many thicknesses, and cut your own. Or possibly use the blue stuff.
Bro.Greg
Post by Bro.Greg » Wed Mar 19, 2014 7:51 pm
Thank you Bryce that was my next step I thought I would see if anyone know
a place where I could still get one before a built one.
rock digger
trans gasket
Post by rock digger » Fri Mar 21, 2014 6:49 pm
The gasket was discontinued by deere long ago,they now use a loctite gasket compuond sold at many parts stores and by deere dealers, I am not sure of the number,but I used it recently on my 450b trans case seemed to seal just fine. Remeber to only tighten those bolts to 35ft.lbs or they can break. I could tell you all about that problem. If you can't find it I can get the number next time I am in my shop. Good Luck,
There is always another rock under this one!
Post by Lavoy » Sun Mar 23, 2014 10:20 am
It is current, $20, just subs to a different number.
