newer 440ICD
scampr
newer 440ICD
Post by scampr » Fri May 02, 2014 5:04 pm
This should be a easy one. I just picked up a newer 440 ICD with the up and down throttle vs my old style. The PO had tried and tried to start it and asked all sorts of ?s on here. I got it for parts but it really isnt that bad so was going to try to start it. I am sure the problem is its turning over very slow. MY question is there isnt a shut down cable on it. Is the throttle also used to shut it down? I would think not... but before i dive to deep thought i should ask. Thanks...
Post by Lavoy » Sat May 03, 2014 11:04 am
You can adjust the throttle so it will kill it, but not the correct way, there should be a shutoff cable.
Make sure you have fuel coming out of the return line when cranking. Check the line from filter to pump, I had one collapse internally and wouldn't let enough fuel through.
Post by Stan Disbrow » Sat May 03, 2014 12:19 pm
Oh, I hate it when that happens! Works when you stick the end of the hose into the coffee can. Does not work under working pressure!
scampr
Post by scampr » Sat May 03, 2014 2:23 pm
Sorry i didnt get back.. I got it running after changing the starter and got the shut off all figured out... but i mainly wanted to see how i would stand if i used it for parts. ALL the clutches are stuck but it does move in all gears and the reverser works in forward but slips in reveres. MY main goal was to swap trans and add the reverser with the 440 i dozer I have now. Other than the tracks this really isnt that bad... so now torn.. do i keep both? lol
sooooo do i need a dozer and a loader too..???? :)
Post by jtrichard » Sat May 03, 2014 2:32 pm
its hard to have to many tractors :D :D :D
gus
Post by gus » Sat May 03, 2014 2:46 pm
jtrichard wrote:its hard to have to many tractors :D :D :D
That's what I keep trying to tell my wife.... She ain't buying so far :roll: :lol: :lol:
Post by jtrichard » Sat May 03, 2014 2:50 pm
ask her how many pairs of shoes she has? tractors are like shoes much better in pairs :lol: :lol:
scampr
Post by scampr » Sat May 03, 2014 4:53 pm
Its easier to sneak extra guns in ,,, but she is catching on to the 3 crawlers,2 tractors and i didnt get away with sneaking in a 1970 chevy
pickup.. but i tried.. :P
gregjo1948
Post by gregjo1948 » Tue May 06, 2014 6:39 pm
I had a 440ICD a couple years back and I don't remember a shut down cable on it. I think I just closed the throttle. I do have a cable on my 1010 but, it doesn't have the Detroit diesel. gregjo1948
scampr
Post by scampr » Tue May 06, 2014 8:18 pm
It has the place for it but over the years and owners it disappeared. Its all good i got it running after 2 owners gave up on it and still trying to decide if its going to be a donor or i should do ALL the clutches and find tracks for it and hide it with the others...lol thanks for the repy
whiteclipse16
Post by whiteclipse16 » Wed May 07, 2014 5:55 am
With the amount of the shut offs that are lost, I wonder if there'd be any interest in buying them if I had them made?
I was finally able to find one for mine but it took about 2 years of searching so I could use it as a template.
Ben
Post by Lavoy » Wed May 07, 2014 10:01 am
Standard T handle choke type cable is all you need unless the corresponding components are missing on the engine.
whiteclipse16
Post by whiteclipse16 » Wed May 07, 2014 10:10 am
Yea that T-handle is common and easy to find. There is a small piece that is up on the engine that the T-handle cable connects to. That small piece pushes against the throttle linkage.
That small piece is what gets lost usually I think. It'd be pretty simple to make.
Ben
