1956 420
boler76
1956 420
Post by boler76 » Thu Jun 12, 2014 6:34 pm
starts and runs properly when cold, after working(plowing and discing) for approx 1/2 hr, begins to misfire and eventually stops and wont start till cools down for overnight, has plenty of gas running out the carb drain when opened, has spark but very weak, what would you think might be the cause, thanks
Post by Stan Disbrow » Thu Jun 12, 2014 8:47 pm
Sounds like cracks in the insulator tips of the spark plugs. Modern ethanol laced gas can detonate and cause microcracks to form. Been there, done that.
whiteclipse16
Post by whiteclipse16 » Fri Jun 13, 2014 7:36 am
Could possibly be a bad ignition coil that's breaking down as it warms up.
Ben
dr1zsk1
My Experience
Post by dr1zsk1 » Fri Jun 13, 2014 8:22 am
I had a similar situation.
I did the following - not exactly sure which one fixed it.
New Distributor Cap
New Points / Condenser
New Wires
New Rotor
New Coil
New Resistor
Fixed the problem completely - Based on what I was getting in feedback here I suspect the coil was the problem but It all needed to be changed anyway.
Mike
If man can break it man can fix it .. it just takes time and money.
boler76
56 420
Post by boler76 » Sun Jun 15, 2014 6:30 pm
Thanks for the feedback, will order up some parts and will post back with what I come up with that fixes it
gregjo1948
Post by gregjo1948 » Thu Jun 19, 2014 5:20 am
Possable leak in the intake that expands with heat. gregjo1948
vtjoe
your 420
Post by vtjoe » Thu Jun 19, 2014 1:23 pm
or maybe just TOO lean
1957 420C four roll since 1982
boler76
420 update
Post by boler76 » Sat Jun 28, 2014 7:11 pm
changed coil and condenser and it runs as it should again. thanks for all the input
original possum
Post by original possum » Sat Jun 28, 2014 7:43 pm
If you let it run at idle when the misfiring first begins does this extend the life?
