1010c no power to one track
whollings
Post by whollings » Tue Aug 05, 2014 5:57 pm
While using my 1010c the machine suddenly lost power to the right track. The left still operates normally. What should I suspect my problem to be?
Post by jtrichard » Tue Aug 05, 2014 6:45 pm
Right clutch most likely wore-out or oil on it..... Welcome to the board
Post by Lavoy » Wed Aug 06, 2014 9:38 am
Outside chance you broke a driveshaft, but either way, you will need to pull the final to check. Any questions, let us know.
whollings
1010c
Post by whollings » Thu Aug 07, 2014 4:56 am
Thank you. I was afraid it would be something like that, but was hoping for a miracle.
Post by Tigerhaze » Thu Aug 07, 2014 10:09 am
If the 1010 crawler is like the 2010 crawler, there should be an inspection plate on top of the steering clutch housing that can be removed to see the top of the steering clutch/brake assembly. You would be able to see if there is oil slinged on the steering clutch/brake assembly and possibly even see whether the pinion shaft is turning before you pull the final.
