440 icd oil types
Jaybird
440 icd oil types
Post by Jaybird » Wed Sep 23, 2015 7:53 pm
I know I have seen somewhere but I thought I would ask. What type of oil in my 440icd? Motor, trans, and reverser.
Many Thanks, Jaybird
GaCatskinner
Post by GaCatskinner » Wed Sep 23, 2015 8:48 pm
Motor is 40 wt. I'll check the manual for trans and reverser
Post by Stan Disbrow » Thu Sep 24, 2015 4:47 am
Reverser uses 303 Hydraulic, nowadays Hygard. Trans and final drives use 90 wt gear oil. Detroit engines use Delo, 40 wt as already mentioned.
Jaybird
Post by Jaybird » Thu Sep 24, 2015 5:40 pm
Many thanks. I can't get hygard locally. Is the traveler brand from tractor supply any good? And where can I get the 40 wt delo oil?
shinnery
Post by shinnery » Thu Sep 24, 2015 7:23 pm
I went to one of the oil jobbers in the nearest big city (Abilene, Texas) and he got me a case of Delo 100 {not 400} it was only available in quarts of HD40 or I would have tried 30 wt.
Post by Stan Disbrow » Fri Sep 25, 2015 5:35 am
The Tractor Supply version of the old 303 will work fine.
pop pop
Post by pop pop » Fri Sep 25, 2015 6:14 am
boat supply stores seem to have the Delo 100 in 40wt.
the detroits were very popular boat motors.
last time i paid $18 a gallon. :P :P :P :P :P
a bit pricey but i was just happy to find it,
:o :) :D :shock: :? 8) :P :wink: :wink: :D :) :o
Post by Stan Disbrow » Fri Sep 25, 2015 6:47 am
I see Delo 40 wt in the auto parts stores around here, on the shelf with all the other diesel oils.,
Post by Lavoy » Fri Sep 25, 2015 7:00 am
Delo 100 is hard to find around here, only know of one jobber 30 miles away that has it.
whiteclipse16
Post by whiteclipse16 » Thu Oct 01, 2015 10:21 am
Yep, you guys are probably seeing the DELO400. It's very common around here, but the Delo 100 is not. You want the Delo 100. If I remember right it's got the lowest ash content.
Ben
Post by Lavoy » Thu Oct 01, 2015 6:16 pm
Regardless of brand, low ash is the ONLY oil you run in a two stroke Detroit.
