gearmatic winch roller fairlead build
I hope it works, the only logging I have done so far with the crawler is a chain hooked to the drawbar. Which worked fine until the fender got too slippy with snow and I went for another ride off of the side. Funny I did this twice, I guess I didn't learn the first time!
Well after months of learning alot about a gearmatic 8a winch, I finally got everything working correctly and I must say these winches are amazingly strong! It spools out easily, surprisingly without having any birds nests, and the brake is really strong, and the clutch grabs with little movement on the controller. I was afraid of damaging the brake band while dragging logs when driving forward, so I had left the drawbar attached but I don't know if the drawbar is necessary any more. The added fairleads really aid in saving the metal casting and also the winch cable. It really is critical to have the winch winching in nice and straight, but it nice to know the fairleads will protect the casting if something goes wrong, which there always seems to be something that moves when winching logs. Time will tell how they hold up but so far so good!
- Paul Buhler
Hello Paul, I ended up setting the clutch bands at a maximum of .014. My bands were a little out of round to begin with, but its working great as is. The epoxy so far has been holding up very well also! Send me a PM if your still interested!
your project
nice post and pics but I personally would like to see pics of your ROPS enclosure while you are at it. I need some inspiration!
1957 420C four roll since 1982
Re: your project
No problem vtjoe, ill get some photos since we finally got enough snow to run the tractor/snow blower so ill take some photos while in the barn and put them on a Photobucket library for you.vtjoe wrote:nice post and pics but I personally would like to see pics of your ROPS enclosure while you are at it. I need some inspiration!
Re: your project
Here you go vtjoe, I think it will work.....
http://s1160.photobucket.com/user/terra ... eshow/FOPS
Also a completed photo of the roller fairleads.
Users browsing this forum: No registered users and 9 guests
