jd 450d will not move
lugnut
Post by lugnut » Tue Jul 19, 2016 6:58 pm
I need help, dozer was running great. I went from reverse to high and it made a funny sound and hasn't moved since. I pulled the top off the transmission and nothing is moving when you start the engine. Any help is greatly appreciated.
Dave Buchanan
Post by Dave Buchanan » Wed Jul 20, 2016 8:01 pm
may be main engine clutch
lugnut
Post by lugnut » Thu Jul 21, 2016 12:41 pm
Main clutch feels good, it had never slipped.
Dave Buchanan
Post by Dave Buchanan » Thu Jul 21, 2016 4:13 pm
You have the cover off the top of transmission and no shafts turn when engine is running . I have seen center of clutch break out .
lugnut
Post by lugnut » Thu Jul 21, 2016 6:54 pm
Does the engine clutch and transmission hook up the same as a vehicle
Dave Buchanan
Post by Dave Buchanan » Thu Jul 21, 2016 8:48 pm
With cover off clutch pedal out engine running should sling oil everywhere. Look for a small pipe plug should take allen wrench, this is were you check oil pressure . If main shaft is not turning it will not have oil pressure , main shaft also turns the transmission oil pump.
Dave Buchanan
Post by Dave Buchanan » Thu Jul 21, 2016 8:53 pm
And yes like a vehicle
Post by Tigerhaze » Thu Jul 21, 2016 9:10 pm
My money is on a broken HLR input shaft due to loose or broken transmission bellhousing bolts. That would also cause no function to the HLR or anything behind it while the engine is running.
lugnut
Post by lugnut » Fri Jul 22, 2016 7:46 am
All bolts are tight, where is the HLR shaft location
DrLoch
Post by DrLoch » Fri Jul 22, 2016 8:04 am
Tigerhaze wrote:My money is on a broken HLR input shaft due to loose or broken transmission bellhousing bolts. That would also cause no function to the HLR or anything behind it while the engine is running.
That would be my guess. If the HLR is neutral and the input shaft is good with the cover off you will see the clutch drums spinning.
450C Track Loader
291457T
Post by Stan Disbrow » Fri Jul 22, 2016 10:22 am
All you have is engine clutch and HLR input shaft. If the HLR cover is off and engine is running and the part you can see is not spinning, you have one of those two busted.
Post by Tigerhaze » Fri Jul 22, 2016 2:59 pm
I guess if there is a silver lining is that both the engine clutch and the HLR input shaft are in the same spot so you will find out either way.
Dave Buchanan
Post by Dave Buchanan » Fri Jul 22, 2016 8:03 pm
A shop manual would be a big help , I have seen them on ebay around $200.00.
lugnut
Post by lugnut » Sun Jul 24, 2016 6:02 pm
Is there a coupler connecting the input shaft, or the HLR
Post by jtrichard » Sun Jul 24, 2016 9:00 pm
NO just the input shaft JD calls it a drive shaft AT35195 GOOD news is 450 BCDG all use the same one
