what are the 2 plugs for that are over rear axle JD450b doze
RP
Post by RP » Mon Oct 17, 2016 11:49 am
There are 2 plugs over the rear axle of JD450b dozer (on both sides of dozer). Any idea what they are for? I can't find anything about them. Thanks.
I have a pic, but don't know how to attach it.
Post by jtrichard » Mon Oct 17, 2016 12:03 pm
Here is how to post pics
http://www.jdcrawlers.com/messageboard/ ... light=post
IF you are talking about the ones that are on an angle they are for steering clutch removal
Look here page 4
http://www.jdcrawlers.com/messageboard/ ... c&start=45
RP
2 plugs over driveshaft on JD450b dozer
Post by RP » Mon Oct 17, 2016 2:29 pm
Are both plugs over driveshaft used for steering clutch removal? I was told the one right above the driveshaft was used to fill the final drive. Thanks.
Re: 2 plugs over driveshaft on JD450b dozer
Post by jtrichard » Mon Oct 17, 2016 4:40 pm
RP wrote: I was told the one right above the driveshaft was used to fill the final drive. Thanks.
NO! NO! NO! AND NO!........ The angled one is to get to the set screw on the clutch/brake drum so you can remove the final drive pinon gear the one just forward of that one is to remove a brake band anchor pin ..... DO NOT PUT ANY OIL IN EITHER ONE as you WILL DESTROY the steering clutches and brake band
RP
how to fill final drives on JD450b dozer
Post by RP » Mon Oct 17, 2016 5:01 pm
So how do you fill the final drives on JD450b dozer? Thanks.
Post by jtrichard » Mon Oct 17, 2016 5:29 pm
There is a pipe plug on the rear OR on the inside of the final drive just above the oil pan
RP
fill final drive , JD450b dozer
Post by RP » Mon Oct 17, 2016 6:27 pm
Thanks for your help. I greatly appreciate it.
Users browsing this forum: Johntc23 and 14 guests
