450C Rear Crankshaft Seal Install Tool JT30042
DLE55
Post by DLE55 » Thu Feb 02, 2017 10:26 pm
Hello. If anyone can help, I need the measurement of the depth of the step on the face of a JT30042 rear crankshaft seal install tool. I need to build a JT30042 seal install tool for my 1120 tractor. According to what I could find on part numbers, my 450C and 1120 tractor can use the same rear crankshaft seal. RE44574 or AR92893. This is a seal with the built in wear sleeve. It is not two separate pieces. The seal and wear sleeve must be pushed in together or it will be damaged. I do not know what the step should be from the face of the wear sleeve to the face of the seal.This is not explained very good but if anyone has a JT30042 seal install tool and could give me the depth of the step on the face, I would greatly appreciate it.
Thank you,
David Edwards
jsal
Post by jsal » Sat Feb 04, 2017 7:52 am
I am working on my 350 engine have rear seal to install been buying parts form John Deere dealer going to see if they will rent one out ? did cat engines before the dealer I worked with would let me use theirs !
JIM
DLE55
Post by DLE55 » Sat Feb 04, 2017 2:58 pm
I measured the seal and built the tool out of aluminum. I did not buy my parts from John Deere. I guess I should have tried to rent the tool from them. If it does not work I will start over and try to rent the tool.
jsal
Post by jsal » Mon Feb 06, 2017 11:33 am
Pulled my rear cover off and removed the seal to my surprise the seal was nothing like I had encountered before it is a flat face that runs against the
inside surface of the cover the other suprise is the price $ 249.00 from deere
found one online they wanted 125.00 but did not have the seal found one one E bay $229.00 ouch .there is nothing cheap about fixing machines two other places I checked with wanted $285 00
JIM
Users browsing this forum: No registered users and 125 guests
