Logging Set-Up
- CuttingEdge
Logging Set-Up
I have been on the forum for awhile now, but just got pictures to post, so here is my logging set up. It is my 350D towing a Wallenstein log trailer. It really is a nice set-up. (As with most of my pictures, my wife Katie is modeling again).
Re: Logging Set-Up
Best of the best, i must say. Bruce.
More pics!!
More pics!!
Re: Logging Set-Up
I must say I like that "factory" seat in your 350 D.
- CuttingEdge
Re: Logging Set-Up
Here is some logging pictures; though this log trailer does more than that. It comes with a dump body that holds a yard of gravel, a backhoe, and since the grapple rotates 360 degrees, it can power a post hole auger too. Not one to sit on my bottom and do nothing, I fabricated an upside down woodspliter so I don't have to do any lifting when I split my wood, as well as a grader blade to get my logging roads really smooth and flat.
If you look close towards the hitch and on the right side (by Katie's thighs) you will see the 6 hp engine that powers the hydraulics of this trailer. Because of that I use it on my tractor, bulldozer or SUV by simply pulling the hitch pin. I use it A LOT behind our Ford Explorer because it is fast,especially at grabbing big round hay bales out of our fields for our sheep.
- CuttingEdge
Re: Logging Set-Up
This is the log trailer with the upside down woodsplitter.
What I did was build a "carrier" as I call it, which is a 3 point arrangement that holds a external hydraulic tank, seat and hitch. Wanting more speed and power for my splitter, I put a Prince PTO pump on my tractor to power the upside down woodsplitter. The speed can be adjusted by adjusting the tractor throttle. Then, so I do not have to stand all day, I put a seat on the back which has all functions; tilt, slide forward and back...even lumbar support! I also added an arm rest that has the splitter valve...and of course a cup holder! The log trailer is attached to the carrier by a hitch.
Then I redid a homemade splitter so that it hangs upside down. I am not sure if you can see how the 4 way splitter works, but I hover my splitter over the round of wood, pinch it, but do not split it, until it is over my dump body (not shown) then finish splitting it. Then I drive over to my woodshed and dump the wood out. In this way I never have to pick up a block of wood..I sit on my butt! (As a side note, I pick the firewood up to waist height with my grapple beforehand so that when blocking up firewood, my saw does not hit dirt, nor do I have to stoop over all day)
- CuttingEdge
Re: Logging Set-Up
This is the grader blade...
The problem with 3 point hitch mounted blades is that they are not very smooth because they follow the tractor in going up and down, but I realized if I mounted my grader blade between my log trailers bolt on hitches, I could extend the length and use its walking beam, 4 wheel suspension to leave a really smooth roadway. So that is what I did, making a drop hitch to get the clearance I needed.
This works incredibly well. I maintain a half mile of heavy haul road for my logging trucks and it is so long that in 2 passes the roads are properly crowned and smoothed. I think I have $35 in the whole build including bolts and welding rod.
- CuttingEdge
Re: Logging Set-Up
Finally just some random pictures of it doing odd-ball work like moving rocks so you guys can see the dump body, the backhoe with me digging a waterline to one of the sheep barns, and moving round bales. It really is the swiss army knife of implements on this farm. There is not a day that goes by...summer or winter...that it is not used for something.
One note on the first picture. You will see my tractor, then my winch, then the log trailer. This works really well because when my log bunks are on (and not my dump body) I can fell a tree 150 feet away from the tractor or bulldozer, winch the tree to me, then cut the tree into log or pulpwood lengths and load it onto the trailer. I can get about 500 bf or 1/2 a cord per trailer load.
- CuttingEdge
Re: Logging Set-Up
I actually got this idea from PondHogVT. I was visiting him and I saw how the seat on his Kumatsu came from a car. Mine came from a Ford Focus. It works well, is very comfortable and bolts in and out with two bolts so access to the clutches is quick and easy.
whiteclipse16
Re: Logging Set-Up
That's really impressive work. You've definitely figured out how to get the most out of the Wallenstein.
Ben
- Paul Buhler
Re: Logging Set-Up
Nice to see your creative problem solving. You should get great satisfaction every time you use one of your creations. The back you save is your own. Thanks for sharing. Paul
