A couple of my roller grease fittings squeeze the grease back out of the zerk. Are these bad zerks that need to be replaced or is there a larger internal roller problem? Where to get new zerks if that's the problem?
1966 diesel 350, 5 roller.
350 roller grease fitting
Re: 350 roller grease fitting
The zerk has a ball right at the opening with a spring behind it. When the spring gets weak, it leaks. The thing is built such you can't fix it. So, you just replace it.
Ok I'll check out Napa
