JD 550G transmission filter
Can someone tell me where the transmission filter is on JD 550G dozer is located. Serial no. is 783906.
Re: JD 550G transmission filter
Good morning,
Your post would likely get more review and input if you put it in the late model crawler forum. There are some here who have or have had 550's and may help you more. I don't know where the transmission filter is on a 550G but think it is in the same compartment as the hydraulic filter (right side of the machine in compartment below the armrest). There should be a decal on the door of that compartment showing service points if it has not been removed or painted over. Your operator's manual will help you out, it would be a good investment if you don't have one.
Post moved.
I would have to believe that the location is in the service manual.
