Carrier roller on 450C
Looks like I will be changing a carrier roller on my 450C dozer soon. Do I need to break the track for this or can I slack off track tension and block the track up enough to do it intact?
Re: Carrier roller on 450C
No need to split the track. You may have enough slack that you can lift or jack the track off the upper idler. If not, you may let a little grease out of the front idler tensioner. Best regards.
Users browsing this forum: No registered users and 59 guests
