scarifier pics
scarifier pics
Post by NNAATZ » Thu Jun 07, 2007 10:31 am
i was wondering if some one could post some pics of a scarifier. iwould like to build one, i guess what i need to see is the lift arms and mounting brackets and the width
thanks nick
Post by Tigerhaze » Thu Jun 07, 2007 2:01 pm
Hi Nick-
I think I have some pics of scarifiers for the 2010 crawler. They're at home; I'll have to post them up a little later this evening if no one else has some handy.
Post by NNAATZ » Thu Jun 07, 2007 2:50 pm
ok thanks, i have never seen one in person
Post by Tigerhaze » Fri Jun 08, 2007 2:15 pm
Hi Nick-
I have attached a number of scarifier photos- they are from various JD machines. All the photos were scavaenged from the 'net (I wanted to know what they looked like for future reference also) so they aren't the best views or closeups. I like how the one scarifier is hed in place with the come-along :lol:
Scarifier on 2010
Scarifier on 1010
Scarifier from a 350
Scarifier on 450
Hope this helps!
digitup
Post by digitup » Sat Jun 09, 2007 4:00 pm
Put on a new coat of paint and they look like the ones you get today .As Deere got into the 60s you could get two different scarfires those pictured were a non parallelogram unit .The parallelogram rippers were at a constant angle and heavier built .My friend had a parallelogram unit and they didnt get the clearance that the other unit pictured got me .Digitup.
Post by Tigerhaze » Sun Jun 10, 2007 9:38 am
digitup wrote:Put on a new coat of paint and they look like the ones you get today.
Hi Digitup-
Would newer scarifiers bolt directly to older crawlers like a 2010 (i..e. the bracket bolt holes and mounts are the same)?
digitup
Post by digitup » Sun Jun 10, 2007 10:48 am
Just to make things difficult Deeres changed at the G series .The old bolt pattern was changed and the PTO speed and direction was also changed .I cant help but think that parts were just too easy to interchange and they had to make them different.I put a ripper on one of my 550Gs and a winch on the other .The Gs didn't need either to balance up but the ripper is totally different in bolt pattern then the older machines .Also lighter and bulkier of the two options .If you have hard soil conditions than the ripper is a nice addition .If you are putting one on to go into sand or swamp then spend the bucks on a winch this will balance up the older machines better as well as pull you out of a bad spot .My little 350 D widetrack has a winch and I recommend that application 100%.My neighbor has a crawler loader with a ripper this is the better of the two options that he could have .I bought a 1010 dozer up north several years ago and it had a winch on the back and the 4 rippers were built into the back of the blade . The old guy I bought it from said that this was a dealer option and when I bought it it looked like it did the day he bought it .I sold that dozer on the ferry back from picking it up on Manitoulin Island .As I said earlier I owned a 1010 for 4 hours and didn't get to do more than load and unload it .I would put ripper teeth on the blade if I had the proper adapters for this application .That was a nice set up and it didn't stick out the back either.Should see if Lavoy could get those weld on ripper sockets it would be a cheap and handy option .. Digitup.
Post by NNAATZ » Fri Jun 15, 2007 6:29 am
hey thanks for the pics. the scarifier is going on a 420. i would have gotton back to sooner but i was on a fishing trip any way not the same tractor but still vary helpful
thank again nick
Post by Lavoy » Fri Jun 15, 2007 9:48 am
Nick,
Now that I think of it, I have a jobber scarifier mount, the portion that goes on the crawler. If you are going to fab something, it might save you a lot of time.
Post by NNAATZ » Fri Jun 15, 2007 12:47 pm
do you mean the piece that conneacts to the wieght bracket and that holds the teeth. all i have is a ratty opperaters manual to look at .
show pics if you have time i would be interested
nick
Post by Lavoy » Sat Jun 16, 2007 10:00 am
Nick,
I didn't remember that you had a loader, this one is for a dozer machine only, or at least not a crawler with a Deere loader, sorry.
Post by NNAATZ » Mon Jun 18, 2007 6:45 am
ok thats fine
Users browsing this forum: No registered users and 304 guests
