40C track parts?
40C track parts?
Just curious, are the pins & bushings still available for the track on my 40c? I see some bushings on ebay. Just want to start gathering parts before the next pandembic. (perfect time to rebuild a track during lockdown) I know it is a big ordeal to fix the track....................but.................it is fun, right? I love a challenge, ...I love this little dozer!
1954 JD Crawler, 1930's International A, 2015 LS XR4040 (with a hoe) Huge Brad keselowski fan #2
Re: 40C track parts?
Normally readily available, I have some in stock, but will be installing them shortly, few day delay to get more.
They will have to be installed with a "track" press.
Mr. Lavoy, should I just call you on the pricing for those parts? I have some sort of a press........gotta figure out how it works. The left side is what concerns me, I think the last owner did alot of work to the right. Thank you, hank
Yes, you can call me.
You don't need just some sort of press, you need a purpose built track press with the correct tooling for the rails you are working on.
original possum
Do both sides at the same time or the dozer will walk crooked for a long time.
Mr Lavoy, I can not load a pic on here, cuz I am computer stupid, but if you have the original service manual, (as I do, which was cool to come with my crawler) page 165-10-2 shows exactly what I have. I believe the old timer that had it before me was a hell of a machinist. I have the press guide thing, all the pressing pins, bushing pushers, & backing plates? If worse comes to worse, I will just send you a pic to your emial. The only thing different about my press thing, is that instead of it sitting on a side press, the gentleman before me put a pretty solid backing plate. Guessin; he used some sort of cylinder in there. I have a good friend that is a production manager at a large machine shop, I think I can make it work. i'm sure you have seen this type of track support/press thing? Hank
Out of the office, so don't have access to my manuals, sorry.
Users browsing this forum: No registered users and 35 guests
