350c thrown track
Gwilkrrs
350c thrown track
Post by Gwilkrrs » Wed Jul 20, 2022 5:32 pm
So when it rains it pours…….
I threw the driver side track today. I loosened the jamb nut and took the bolt all the way out and tried pushing the front idler back to loosen the tension but the idler wouldn’t move back.
Did I do something wrong?
How do you reset the track?
Al Swearengen
Re: 350c thrown track
Post by Al Swearengen » Wed Jul 20, 2022 6:26 pm
Never thrown a track, but on my 450G I removed the grease zerk/ball that allows adjustment, and placed a block of wood between the track and my 6 way blade (when I put on new rails), released all tension easily.
'99 450G 6-Way
Post by Jim B » Thu Jul 21, 2022 4:33 am
There is supposed to be a steel check ball under the bolt you removed. Be careful not to lose it, you need it to seal the hole when you put it back together. The ball is the seal the bolt with locknut holds it in place. The ball often comes out in the grease, that will push out when you collapse the adjuster, and doesn't get seen and is thrown out with the grease.
You may be able to use the bucket roll and a heavy block (like a 6 x 6) to push the idler back. If that doesn't work, use a block and hydraulic jack between the bucket and idler. Getting the track itself back on the idler is bars, com-a-longs, jacks, chains and maybe using the loader. Another machine may help. There is no one fits all answer, sometimes they go back on easily, sometimes not.
Gwilkrrs
Post by Gwilkrrs » Thu Jul 21, 2022 5:25 am
ok-
so take the bolt out (look for small check ball) and brute force slides the idler back- i guess i was thinking that the idler would come back easier......
i will try the block and jack-
B Town
Post by B Town » Thu Jul 21, 2022 7:32 am
It is possible your adjuster has perished and is frozen. Try compressing the idler and adjuster. But if it doesn’t compress with reasonable force, the adjuster will need serviced, rebuilt, replaced.
Best regards, Bruce
original possum
Post by original possum » Thu Jul 21, 2022 10:46 am
And if brute force alone doesn't collapse it then make sure exposed portion of ram is clean and pepper the tube part with a medium sized hammer while applying that force. Enough to shock it but not enough to deform it. You can draw a line on the ram to see if it moves. Worked for me a number of times.
Gwilkrrs
Post by Gwilkrrs » Sat Jul 23, 2022 1:06 pm
So I was able to add grease and have it extend a little and then retract with force back to where it was ……..
I have it off the rail and vertical so I could have the tube upright and soak it with penetrating fluid to see if that helps……
And there wasn’t a bb below the bolt to hold in greese
Post by Jim B » Sat Jul 23, 2022 5:06 pm
Unless it has been changed to something other than a JD adjuster, or someone has replaced parts incorrectly, it should have a 3/8" steel ball under the set screw that lets the grease out. See item key numbers 7, 8, and 9 in the parts drawing.
https://partscatalog.deere.com/jdrc/sid ... ion/pgId/7
The Jug
Post by The Jug » Sun Jul 24, 2022 7:11 am
Had problem moving mine till i used blade to raise front end to take pressure off track tensioner . OOPS :D
Gwilkrrs
Post by Gwilkrrs » Sun Jul 24, 2022 2:38 pm
Mine is a loader so I can’t use the blade to push back
I was able to take track off all way and block loader up off the ground- I then wrapped a chain around sprocket hub and front idler and used a chain binder to force the piston in some- it moved in!
I put tension on the chain and then “bumped”the housing with a sledgehammer and every time I bumped it grease posed out a bit so I kept repeating this-
The chain tightening itself wasn’t enough tho-
I ran out of time so I left the chain on tight until I try again to see if it compressed enough
jimmydiesel
Post by jimmydiesel » Sun Jul 24, 2022 6:46 pm
Heating the housing / cylinder may help. 150-200 degrees.
Don’t over heat it.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Gwilkrrs
Post by Gwilkrrs » Wed Jul 27, 2022 5:30 am
i ordered the $5 BB even though mine didnt have one installed when i took the bolt out- i see an indent at the bottom of the bolt where the BB would seat into so the bolt is right.......
hoping to get back to working on this this weekend
Gwilkrrs
Post by Gwilkrrs » Sun Jul 31, 2022 7:34 am
I couldn’t find or figure out the master link on the track so I fought the whole track.
I was able to use come along and chain which ratcheting binders- after 3 hours (trial and error and first time) lots of blood and 2 broken fingers (track weight was too much for the first comealong)- the track was put back on and I was able to tension it
So happy.
I now need to figure out how to get the stuck bolts out for the rock guard over the spring and patch it to reinstall
77 Ford
Post by 77 Ford » Tue Aug 02, 2022 7:17 am
The first time I threw a track it took me hours to pop back on. The last time I threw a track it took 30 minutes (not including the time to get the tools)..... you learn alot doing that.
JD- 450C track loader
Serial #208336T
LeonardL
Post by LeonardL » Wed Aug 03, 2022 7:19 am
The first one I helped with was on a fire line in Shannon county Missouri. Nothing like having a fire creeping up to motivate your progress. :D
Users browsing this forum: Google Adsense [Bot] and 133 guests
