1010 Crawler Loader no start after using jump box
milesofmike
Post by milesofmike » Thu Apr 06, 2023 10:51 am
My 1010 crawler loader was having trouble starting. I suspected a drained battery so I used a jump box. Now it won't turn over at all, but it seems to be drawing current from the battery. I suspect the voltage from the jump box was too high for the ole girl. Before I rip it apart and guess what it might be, have any of you had a similar experience and know what to check first? I'll be looking at the ignition switch first. I also read there is a resistor between the switch and starter so that will be the next thing to check, aside from wires.
196x JD 1010 Crawler Loader
Re: 1010 Crawler Loader no start after using jump box
Post by Jim B » Thu Apr 06, 2023 2:57 pm
Could it have jammed the starter drive into the ring gear. You will need to loosen and wiggle the starter; you might even need to remove and reinstall it to get it unlocked, if that is what has happened.
milesofmike
Post by milesofmike » Wed Jul 26, 2023 12:53 pm
That was it! Removing the starter and putting it back in did the trick. Thanks!
