440IC Distributor Questions
- Roger440IC
- 430 crawler
Hi, the shaft on my D-R 1112571 distributor is so worn that it won't open the points when they go over the small lobe unless I push the shaft in that direction. My parts manual doesn't show a part number for the bushing but the service manual shows a bronze bushing. Does anyone know where I could find one of these and /or what the specs are for it? Also, what is the recommended lubricant and quantity that you should put in the oil reservoir in the base of the distributor? Thanks, Roger
440-IC
420-U
420-U
- Roger440IC
- 430 crawler
Users browsing this forum: No registered users and 51 guests
