steering clutch drive shaft
Eric.MacLeod
Post by Eric.MacLeod » Sat Dec 27, 2008 8:38 pm
i just took the left side final apart because the clutches are frozen with rust, when i pulled it apart i found that the throwout bearing had worn a groove around the clutch drive shaft, it has worn into a snap ring and tapered what lookes to be part of the hub, will this be ok? can i just add a new throwout bearing and tube? the tube looks like what caused the wearing on the shaft because the tube is flared out and worn badly. thank you.. Eric
snoopy
Post by snoopy » Wed Dec 31, 2008 6:19 pm
I broke one on my MC a number years ago, so it must be under some stress, If i remember right it is about and inch in diameter. It may last a long time or fail in a week. anybodies guess on how long it may last. at the least i would blend out the score line to relieve the stress. it will be weaker but msy last for a while.
Have Fun!!
1949 MC
"If it ain't broke, don't fix it"
Eric.MacLeod
Post by Eric.MacLeod » Wed Dec 31, 2008 6:40 pm
i have another shaft but the splined end looks like someone tapped on it a little, i pulled the first shaft out of the clutch hub with my hands, the spare shaft that i have will not pull apart with my hands, should i be able to? thank you.. Eric
snoopy
Post by snoopy » Wed Dec 31, 2008 8:16 pm
I would use the spare shaft, maybe clean up the damaged splines with a file. it should slide out fairly easy. maybe some lapping compound, just clean it up real good after using lapping compound.
The fun in this is figuring out a solution to the problem.
1949 MC
