axle movement
Eric.MacLeod
axle movement
Post by Eric.MacLeod » Sat Dec 27, 2008 8:56 pm
sorry for so many questions! when i pulled the sprocket off my 420 dozer i found out that the axle can be moved in and out freely, it is not alot but when i move it in the axle can be lifted a little, when i pull it out it thightens up, is the bearings worn or do i need to shim it up a little? thank you.. Eric
Post by Lavoy » Mon Dec 29, 2008 9:52 am
Pull the inner axle cover and make sure the retainer is still tight. If that is OK, you may be able to shim the bearings in to remove the play.
Eric.MacLeod
Post by Eric.MacLeod » Mon Dec 29, 2008 2:47 pm
thank you i will go out and give it a try. thanks ...Eric
Users browsing this forum: No registered users and 59 guests
