Aftermarket tachometer? Are they available for 1010 Crawlers? If so, please let me know. Any help would be appreciated.
Bubba 1010
Information wanted.
- fixedforever
- 430 crawler
- Contact:
There are aftermarket Tachometers available that are called "diesel tachs" that use a sensor attached to the alternator. I just got one off eBag for my '92 Dodge CTD, it is made by "AutoGauge" and is only a 0-6000 dial. Most likely will not work with a generator. You would need a photo-tach to calibriate it.
Yeah, that type of diesel tach needs a tap put into the alternator's stator. No stator in a generator.shinnery wrote:There are aftermarket Tachometers available that are called "diesel tachs" that use a sensor attached to the alternator. I just got one off eBag for my '92 Dodge CTD, it is made by "AutoGauge" and is only a 0-6000 dial. Most likely will not work with a generator. You would need a photo-tach to calibriate it.
92 Dodge shouldn't needed it though. 92 Dodge Cummins is the first year that already has a built in tach sensor in front of the engine - at least the intercooled version does.
