Jd 9300 backhoe
Jd 9300 backhoe
I purchase a 9300 backhoe 4 my 350 crawler, when I hook up the hosesb it will stall the cat . Remove valve PAC took it to hyd shop, tested found nothing wrong. Reinstall valve PAC had my buddy hook up to it with his 450 and stalls his cat. Hoses and quick coupler all check out ok.remove valve PAC again took back to hyd shop,they now think iTs not compatable for this cat. They say I need a piston pump to run it.i thing they are shooting in the dark. Can anybody help me Thanks so much. Mike
JWB Contracting
Shot in the dark
My guess is your hoe attachment was originally strapped to the back of a wheel loader or skidder which have piston pump hydraulic pumps and has a closed centre valve. You will need to install the correct open centre valve.
Last edited by JWB Contracting on Tue Nov 27, 2012 10:09 am, edited 1 time in total.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Mike, one important thing on what Ken mentioned. You will not want to hook the hoe up to your crawler again until you check the configuration because if it is a closed center valve block, you risk blowing the hydraulic pump on your 350. You're lucky it just stalled your engine.
If you do some seraching of the archives on here, you can find a post that desribes how to tell a closed center from open center valve block arrangement. I know I linked to it recently on here so shouldn't be too hard to find, in case you don't have the service manual.
9300 backhoe
I,d like to thank all the guys who replied to my problem with my backhoe. I don,t what I will do but at least I now no the problem mike
