420 hydraulics
gus
420 hydraulics
Post by gus » Wed Mar 20, 2013 9:59 am
What is the GPM needed for a 6 way dozer to operate??
I need to replace my front pump (not factory) and have no idea what it is now and no name or ID on the present pump. Lift Cyl are 3"X20" on my dozer (also after market).
Lu47Dan
Post by Lu47Dan » Wed Mar 20, 2013 8:45 pm
6 to 8GPM should be plenty.
You need to size the pumps maximum output to the top rpm of the engine.
Pumps are sized by cubic inches per revolution,
Cu.in per rev X RPM = Cu.in per minute.
Cu.in per minute / 231 = Gallons per minute.
Hope this helps.
Dan.
1956 420C with GSC blade
gus
Post by gus » Thu Mar 21, 2013 6:02 pm
Thanks for the answers. I was thinking 10 GPM and that's probably where I'll go. I will have to rebuild the mount because the old pump was bottom mounted, directly in the pump housing. Since the probability of snow is near zero now (it's snowing right now) I think I'll wait a while. :wink:
