440ICD oil pressure
scampr
440ICD oil pressure
Post by scampr » Tue Oct 29, 2013 5:25 pm
Bad day yesterday and it got worse when i had to start the 440 that hasnt been run for a few months and was supprised to see no oil pressure. Pulled the line off the block and no pressure there too... Before i start ripping and tearing.... anyone have any thoughts. It usually ran 40 PSI cold and 30 warm.. so this wasnt expected. Thanks...
scampr 440icd, 350B, 47 Farmall H, 55 Farmall cub and ashamed to have a Kabota too
shinnery
Post by shinnery » Tue Oct 29, 2013 6:07 pm
This is your 2-53 diesel I presume? You have checked it is full of oil? The oil filter is just a bypass system on them. You might pull the valve cover and see if the exhaust valves and rockers are getting oiled.
DukeofDeere
Post by DukeofDeere » Tue Oct 29, 2013 6:18 pm
Drop the pan and check the oil pump drive key.
Duke
pop pop
2-53 oil pressure
Post by pop pop » Tue Oct 29, 2013 11:34 pm
how long did you run it ?
maybe the gauge is stuck.
any pressure at the fitting?
did it start ok and run ok otherwise?
scampr
Post by scampr » Wed Oct 30, 2013 4:28 pm
oil pump key that would sure make sense... thanks... to the other replys.. yes good oil in it 2-53 and no pressure at the block i figured the belly pan and oil pan were coming off for sure.. Was going to check the manual and dive in,, but helpful hints always are appreciated :)
DukeofDeere
Post by DukeofDeere » Sat Nov 02, 2013 6:27 am
440 ICD's oil pump is behind the front cover.
May have lost prime?
How long did you run it?
Duke
scampr
Post by scampr » Sat Nov 02, 2013 11:44 am
I saw that in the book... I havent dove into it yet.. ran it long enough to test it .Just was looking at it again and found i was checking the pressure on the return side to the block so will do a little more research but even on the return side i should have had oil coming out the unconnected line. :( I think before i dive into the front i will drop the pan first and check the pickup. Thanks its always nice to hear other ideas before you dive in.
DukeofDeere
Post by DukeofDeere » Sat Nov 02, 2013 1:02 pm
Wouldn't hurt to pull the oil pressure plug and check the spring and valve.
With this off you could crank just a bit to see if oil is flowing at that point too.
Duke
scampr
Post by scampr » Sat Nov 02, 2013 1:07 pm
Success.. !!!!!! on the pressure side i am getting pressure now !!!! return line was plugged...helps to test the right side to begin with before you get stressed..lol was having a terrible day the day it happened wasnt thinking straight. Thanks again
DukeofDeere
Post by DukeofDeere » Sat Nov 02, 2013 2:01 pm
Awesome!!
Been there done that...
Glad she is working.
Duke
Post by Paul Buhler » Sat Nov 02, 2013 6:28 pm
Success.. !!!!!! on the pressure side I am getting pressure now !!!! return line was plugged...helps to test the right side to begin with before you get stressed..lol was having a terrible day the day it happened wasn't thinking straight. Thanks again
Glad you found your problem, and that it wasn't too difficult to fix.
My dad, a pretty good mechanic, used to say that we usually expect/predict the worst when something malfunctions or breaks down. He'd keep that option on the table, but then looked for simpler causes, or root problems and solutions and usually he found one.
That wisdom has saved me a bit of money and extra effort over the years.
J :D :D
Users browsing this forum: Canuck 420c and 13 guests
