350 engine in 1010
original possum
350 engine in 1010
My nephew had a valve head snap off and total the engine in his 1010C gas. He has access to an engine from a 350 and wonders if it will bolt up. Anyone have experience with this?
The short answer is no, I don't believe it will not bolt up to the bellhousing for the 1010 without a lot of custom modifications and then still may not be possible.
If you want a more detailed explanation there are a couple of threads discussing engine mods on 1010s/2010s but essentially they are somewhat orphaned in terms of parts compatibility with other models except for undercarriage. However there are power units and combines that have compatible engines, and you can swap a 2010 engine into a 1010:
http://www.jdcrawlers.com/messageboard/ ... light=1010
http://www.jdcrawlers.com/messageboard/ ... t=1010+350
I had a little time today so found a couple more related threads you can go through on this subject:
http://www.jdcrawlers.com/messageboard/ ... ellhousing
original possum
Remember if he really overpowers the crawler then he is more likely to wear out the remaining drivetrain components (reverser, transmission, and finals) a lot faster and they are not cheap or easy to find either.
Here is an interesting thread about repowers if that is really what he wants to do:
http://www.jdcrawlers.com/messageboard/ ... craigslist
