1956 420
1956 420
starts and runs properly when cold, after working(plowing and discing) for approx 1/2 hr, begins to misfire and eventually stops and wont start till cools down for overnight, has plenty of gas running out the carb drain when opened, has spark but very weak, what would you think might be the cause, thanks
Sounds like cracks in the insulator tips of the spark plugs. Modern ethanol laced gas can detonate and cause microcracks to form. Been there, done that.
whiteclipse16
My Experience
I had a similar situation.
I did the following - not exactly sure which one fixed it.
New Distributor Cap
New Points / Condenser
New Wires
New Rotor
New Coil
New Resistor
Fixed the problem completely - Based on what I was getting in feedback here I suspect the coil was the problem but It all needed to be changed anyway.
Mike
New Distributor Cap
New Wires
New Rotor
New Coil
New Resistor
Mike
If man can break it man can fix it .. it just takes time and money.
- gregjo1948
420 update
changed coil and condenser and it runs as it should again. thanks for all the input
original possum
