2-53 injectors
440dozer
2-53 injectors
Post by 440dozer » Sat Apr 25, 2009 9:59 am
does anyone know where i can find the gauge to adjust the injectors or a way i can adjust them without the gauge? any help is appreciated.
1959 440icd w/831 loader
Randynscottsboro
Post by Randynscottsboro » Sat Apr 25, 2009 10:33 am
You can find the spec in the service manual and use a depth gauge or a caliper with a depth gauge if you can't find the tool. All there is to it is a steel rod with a tee on top and the end turned down to fit into a small hole. You adjust the push rod till it just clears the spring retainer.
2130 HFWD
1120 JD
Case SC
1846 Case skidsteer
2030 JD
450 JD
350 Case crawler
3110D Yanmar
440dozer
Post by 440dozer » Sat Apr 25, 2009 10:36 pm
I found the measurement in the shop manual, my question now is the measurement from the bottom of that small hole or the flat face of the injector body?
shinnery
Post by shinnery » Sun Apr 26, 2009 12:09 am
I&T Manual JD-18 states
"This adjustment synchronizes the no fuel position of each injector by positioning the top surface of each injector follower a certain distance above the machined face of the injector body. This measurement is 1.484 and is made with timing gauge J1242."
I believe the hole is just to keep the gauge at the same place while you are doing the adjustment. That is my 2 cents and you can take it for what it is worth.
jdemaris
Post by jdemaris » Sun Apr 26, 2009 8:00 am
440dozer wrote:I found the measurement in the shop manual, my question now is the measurement from the bottom of that small hole or the flat face of the injector body?
Match the timing tool to the pump/injector # (and I assume you've got original sized pump/injectors.
Users browsing this forum: No registered users and 125 guests
