440IC Final Drive Pinion 13 Teeth
Johndozer
Post by Johndozer » Sun Jun 13, 2010 7:13 am
In the middle of complete overhaul.
Looking for one Final Drive Assembly Pinion Gear 13 Tooth JD# T11031T
1958 JD 440IC with 831 JD Loader
Ser 445807
Post by Lavoy » Sun Jun 13, 2010 11:00 am
That gear is obsolete and hard to find. I believe that I am going to be able to make new ones, but have not had the chance to try yet.
Johndozer
Post by Johndozer » Mon Jun 14, 2010 2:28 am
Can I reassemble final drives and crawler and replace pinion gear at a later date, w/o tearing down everything again?
Remove Final Drive Bearing Cover and Slide Pinion Gear Out???
Ser 445807
Post by Lavoy » Mon Jun 14, 2010 7:56 am
Yes, it will be a little bit of a pain, but can be done. Hardest part is getting the outside bearing back off.
Users browsing this forum: No registered users and 104 guests
