model 64 hydraulic angle blade
For sale. 64 angle blade with frame, booms, all cylinders (several rebuilt), pins, hoses, as per picture. Blade needs new cutting edge. $2500. Can deliver to Polks at march sale . PM any questions. Thanks.[/img]
angle blade
the atatchment points on the dozer are included with this setup ? the 1010 that i have just has a push manual blade and i am showing some interest in the set- up and just asking is there anything missing that i require to install on the frame
kt
- JD440ICD2006
Curious, how are the ends that connect to the blade of the the angle cylinders (two in the middle of pic) held on? Are they screwed on or spun welded?
Thanks,
Thanks,
angle blade
are the hydrolic pumps the same for the 1010 non angle blade as the hydrolic angle blades - the pumps are the same out put ? and the lines are all that is nec to change up or was the pump a higher output ?
kt
Users browsing this forum: No registered users and 20 guests
